11 years agoCPU and FPGA execution simultaneously
Hi ,
I amd using the OpenCL on De5. <first question> Could CPU and FPGA execution simultaneously ? (When I enqueue a kernel to FPGA , and this moment CPU is idle.) <second question> If there are lots of branch condition in kernel code , how to optimize code ? Is there any good example to reference ? It seems that aoc compiler could not compile complex code and it could compile failed : ( <third question> When the kernel code compile error , the error message always shows the error is happened in *.v file. But I am not familiar with verilog / VHDL. So is there any method to provide the simple error message ? For example : syntax error is at line xxx .. Thanks : DDNo RepliesBe the first to reply
