8 years agoCounter design using QSYS & NIOS PROCESSOR?
Hi, I am trying to implement 8-bit counter design using QSYS and NIOS Processor. please verify the design and tell me the modifications. I need to run the Counter design using QSYS & NIOS ...
8 years agoA PIO (parallel I/O) component is not a counter. If you want to integrate your counter code into Platform Designer, you have to turn it into a component using the Component Editor and add it to the system.
Also, your software code is trying to do a read on the PIO that looks like it's set as an output.
