10 years agocounter and realization clock - compilation OK / simulation Not OK
Hello dears developpers , I'm realizing a little progressive project in VHDL. I use for that the Quartus II Web edition (v9.1). Now I have a problem with the clock signal creation......
10 years agoHello Tricky and Susannah,
Thank you for your help. For the frequency of 2Hz, it's just to do blinking a 7 seg display - but i don't know if there will have a best practise to realize a slow clock here my new code with signal synchronisation
-- compteur --
CMPT_ETAT_FUTUR_2HZ : process(compteur_num_p)
begin
if (compteur_num_p >= VAL_MAX_COMPTEUR_2HZ) then
compteur_num_f <= (others => '0');
else
compteur_num_f <= compteur_num_p + 1;
end if;
end process;
CMPT_ETAT_PRESENT_2HZ : process(CLK_1_8MHZ)
begin
if ((CLK_1_8MHZ'event) and (CLK_1_8MHZ = '1')) then
compteur_num_p <= compteur_num_f;
end if;
end process;
-- -- Horloge 2Hz rapport cyclique de 50% --
CLK_2HZ_50P : process (compteur_num_p)
begin
if rising_edge (CLK_1_8MHZ) then
if (compteur_num_f <= VAL_MAX_CMPT_DIV_2) then
clk_2Hz <= '0';
else
clk_2Hz <= '1';
end if;
end if;
end process;
clk_2Hz_SIM <= clk_2Hz;
Still thank for your explanation. Best regards, Philippe
