metaprogrammer
7 years agoCould not find a way to report a Quartus bug
It appears that Verilog preprocessor in Quartus is not quite standard-conformant, the usual string concatenation trick does not work. For example, the following will fail: `define PREFIX .
`define...
KhaiChein_Y_Intel
7 years agoHi VLugo,
It took me some time to figure out the root cause of this error. Thanks for your patience and understanding.
I tried to test the definition in another edition of the Intel Quartus Prime software, pro edition. The compilation was successful. I believe that this error is due to the limitation of the Standard edition software in SystemVerilog language support.
You may refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/po/ss-quartus-comparison.pdf for software comparison.
