11 years agocould Modelsim-altera run in 64 bit mode, or load 64bit C library?
Hi all,
i am using modelsim-altera 10.1d that comes together with Quartus II subscription edition 13.1. There is no linux64 folder or similar so I tried to run the modelsim in 64 bit mode by: $(altera_home)/13.1/modelsim_ase/linux/vsim -64. It would return: Failed to open executable $(altera_home)/13.1/modelsim_ase/linux/../linuxpe/vish in execute mode needed for the option -64. execv: No such file or directory. I also tried the vsim under linuxaloem folder, which also failed. So the question is: could modelsim-altera ran in 64 bit mode? Or is there any way to load some 64bit systemC library. I actually succeeded in loading 32bit libraries, but the one I need to load has some codes that seemingly only work in 64 bit. Thanks! Tie Chen4 Replies
Answer - 64 bit version is only available as a paid subscription version
And mentor will tell you the 64 bit version actually runs slower than the 32 bit. - Altera_Forum
I am using model-sim altera rather than model-sim altera starter.
Do you mean I need to have model-sim SE or Questa? I do not care about the speed for now. I am giving a 64-bit C library and a testbench and the simulation result did not match if I compiled the c source files in 32 bit mode. Thanks Tie Chen - Altera_Forum
Yes, 64 bit requires questa or SE.
Sorry to bother you again. I could not find SE on mentor graphics's website, is it gone?
It seems now they only have Questa or Modelsim PE. I know that modelsim-altera is a special version of PE. Does this means that I have to use Questa?
