Altera_ForumHonored Contributor18 years agoCorrect way to use Components? I want to use a component in my VHDL code but I'm not sure if I'm doing it correctly. LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.std_logic_arith.all; USE ieee.std_logic_unsigned.all;...Show More
Altera_ForumHonored Contributor18 years agoHello Martin, I'll check out, if your suggestion could ease my work. Thank you, Frank
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
