10 years agoConverting Aynchronous UART to Synchronous USART
OpenCores has a very stable uart (attached) that integrates easily to altera/qsys. My goal is to tweak it just enough so that it transmits on the rising edge and receives on the falling edge of...
10 years agoYes, you can latch the Rx data on a 'sync clock'. However, isn't that over complicating it? I'm assuming you'll then have to transfer the recovered data onto the 'system wishbone clock' domain. Why not just use that clock - as the original design (almost certainly) does? And how are you intending to generate the 'sync clock'?
Cheers, Alex
