Controlling NDRange kernel M20K RAM replication
Yeah, this is another one of the stupid thinks the compiler does, but as far as I know, CANNOT be controlled by the user. In fact, in one the earlier versions of Altera's documents it was clearly written that this replication factor cannot be controlled by the user, but they have removed it later. You can check my reply to a user asking a similar question before, and the quote from Altera's older document, here (https://www.alteraforum.com/forum/showthread.php?t=54741). I remember I saw very high replication factors before in one of the NDRange kernels I was working on, and I managed to work around it by using "max_work_group_size" instead of "reqd_work_group_size" and force the compiler to reduce replication factor; you can try to see if that would help in your case.
BTW, it is always a good idea to open a support ticket with Altera and "complain"; when multiple complain about the same thing, they are more likely to fix it.
