I guess you need to calculate, how many pulses you need to send to your motor to move these 50 degree and send them with suitable (low enough) frequency.
1.8 degrees in one step<><>
this my program.,. but still looping. how to stop it in order to move 30 degrees only library IEEE; use ieee.std_logic_1164.all; entity stepper is port ( CLK : in std_logic; tombol_arah : in std_logic; STEP_D : out std_logic_vector (3 downto 0) ); end stepper; Architecture behavioral of stepper is signal cnt : integer range 0 to 3; signal cnt_1 : integer range 0 to 3; begin process (CLK) is begin if (CLK'event and CLK = '1') then case cnt is when 0=> STEP_D <= "1001"; when 1=> STEP_D <= "0001"; when 2=> STEP_D <= "0011"; when 3=> STEP_D <= "0010"; end case; end if; end process; process (CLK) begin if(CLK' event and CLK = '1') then if cnt = 3 then cnt <= 0; else cnt <= cnt+1; end if; end if; end process; end behavioral; - Altera_Forum
this my program.,. but still looping. how to stop it in order to move 30 degrees only library IEEE; use ieee.std_logic_1164.all; entity steper is port ( CLK : in std_logic; tombol_arah : in std_logic; STEP_D : out std_logic_vector (3 downto 0) ); end steper; Architecture behavioral of steper is signal cnt : integer range 0 to 3; signal cnt_1 : integer range 0 to 3; begin process (CLK) is begin if (CLK'event and CLK = '1') then case cnt is when 0=> STEP_D <= "1001"; when 1=> STEP_D <= "0001"; when 2=> STEP_D <= "0011"; when 3=> STEP_D <= "0010"; end case; end if; end process; process (CLK) begin if(CLK' event and CLK = '1') then if cnt = 3 then cnt <= 0; else cnt <= cnt+1; end if; end if; end process; end behavioral; - Altera_Forum
Add another counter, that counts 30 or 50 degrees and when it reaches the certain value it stops rotation. Use enable signal in first process and add a wider counter to the second process.
