14 years agook, I understand now. It is a binary file which when read in an appropriate hex editor shows the memory contents properly. It is a straight dump but it seems to write the bytes in reverse order. ie. from control panel address 0 is shown as 0001 and address 1 is 0002.
I used a freeware program called XVI32 to load the file in windows. As you say I just have to figure out a way to save these hex values in an ascii file using the proper editor. They should add a comment about the file format in the altera documentation.
