12 years agocontrol library name in QIP file
Hi, I see this line of tcl command in my core.qip file. If I understood it correctly, core.qip has been generated when I click "Generate" in Qsys. set_global_assignment -library "core...
11 years agoMy experience with .qip files is that if you create .qip files for your own IP, then you can control the library name. If Qsys auto-generates the library name, then unfortunately it names the library after the first instance name. I made these comments in this thread/document:
http://www.alteraforum.com/forum/showthread.php?t=48928 Perhaps file a Service Request with Altera and ask them for their advice? Cheers, Dave
