12 years agocontinuous averaging using VHDL
I have a question related to VHDL programming. I want to calculate the continuous average. My example code is:
process (clk, reset)
begin
if (reset = '1') then
state<=idle;
out-v...
12 years ago --- Quote Start --- @kaz Just as an example, I am doing continuous averaging for 4 values. Can you check if my approach is correct.
begin
state<=idle;
out_val=0;
elsif(rising_edge(clk)) then
case state is
when idle =>
if req='1' then
state= out_1;
end if;
when out_1 =>
if done='1' then
out_val<=data_in (11 downto 0);
i_valid <=1;
state <= done_st;
endif;
when done_st =>
ack <='1';
state <= idle;
when others =>
state <= idle;
end case;
end if;
end process;
process begin
wait until rising_edge(clk);
valid1 <= i_valid;
o_valid <= valid1;
end process
-- i_valid is control bit and enables when input data is valid
process begin
if reset = ’1’ then
idx <= "0001";
elseif
valid1 = ’1’ then
idx <= idx rol 1;
end if;
end if;
end process;
process begin
for i in 3 downto 0 loop
if (i_valid = ’1’) and (idx(i) = ’1’) then
M(i) <= out_val;
end if;
end loop;
end process;
mem_out <= M(0) when idx(0) = ’1’else
M(1) when idx(1) = ’1’else
M(2) when idx(2) = ’1’else
M(3);
add_sub <= sum - mem_out when valid1 = ’1’
else sum + mem_out;
process begin
if i_valid = ’1’ or valid1 = ’1’ then
sum <= add_sub;
end if;
end process; sum is the output average value. The above code works if I have unsigned numbers. But I want to average the std_logic_vector. The data_in is defined as: data_in: in std_logic_vector (11 downto 0); Kindly help me in solving this issue. Please modify the above code so that I can get continuous averaging values for vector 'out_val'. Many Thanks. --- Quote End --- I don't see how your approach works. If it is me I will just follow the diagram I posted earlier. for example -- not tested
-- input data_in & output assumed std_logic_vector(15 downto 0);
type type1 is array (1 to 31) of std_logic_vector(15 downto 0);
signal stage: type1 := (others => (others => '0'));
signal sub_result: signed(16 downto 0) := (others => '0');
signal sum: signed(20 downto 0) := (others => '0');
-- delay input 31 stages
process
begin
wait until clock = '1';
stage(1) <= data_in;
for i in 2 to 31 loop
stage(i) <= stage(i-1);
end loop;
-- subtract last stage from input
sub_result <= signed(data_in) - signed(stage(31));
-- accumulate
sum <= sum + sub_result;
output <= std_logic_vector(sum(20 downto 5));
end process;
