12 years agocontinuous averaging using VHDL
I have a question related to VHDL programming. I want to calculate the continuous average. My example code is:
process (clk, reset)
begin
if (reset = '1') then
state<=idle;
out-v...
12 years ago --- Quote Start --- I exactly still don't understand what you mean. Can you write down the code if it is possible? ManY Thanks --- Quote End --- writing code is no small job. attached diagram should be clear.
