KCMurphy
4 years agoConstraints for ADC data input
I have an Arria 10 connected to a Linear LTC2165 ADC capable of SDR or DDR operation.
The ADC expects a differential clock provided to time the conversion and produces a differential clock slightl...
KCMurphy
4 years agoIn the simplest form, we were having trouble with data from an ADC.
All data/clock lines from ADC short and same length. Data transitions on falling edge of ADC-provided clock. If the clock is 100MHz, what is the best input_delay to use? We assumed that defining the actual clock and saying the data delay was about 1/2 the period (to account for the negative edge, would allow correct setup time calculation. But it wasn't working.
Later we found a different reason it was not working. But as long as I'm here, what is the proper set_input_delay method for this fairly simple setup?
