17 years agoThis is an amazing resource! Timing constraints is probably the least understood aspect of FPGA development... and the most likely to get you banging your head against a wall asking god why nothing's working. And this document is the best, most clear explanation that I've found. (Which is to say: Altera, why don't you have any good docs on TimeQuest ?!?!) I also love the sheer style and organization.
However, I'm pretty sure page 9 is all wrong. I.e., using datasheet timing data to constrain an external interface. First of all, it is the max output delay (ie input setup time) that is negative, not the min output delay (the hold time). Reason for this is simple. The max output delay should be a large number, just like the max input delay. However, "setup time" is usually quoted as time _to_ the clock edge (eg 2ns) not from it (eg 18ns). So you have to negate it. Hold time, meanwhile, is quote _from_ the clock edge just like other delays. The SDC should look like this: create_generated_clock -name sdram_clk_pin -source $sdram_clk -offset 0.5 [get_ports {sdram_clk}] set_input_delay -clock sdram_clk_pin -max [expr 5.5 + 0.6] <ports> set_input_delay -clock sdram_clk_pin -min [expr 2.5 + 0.4] <ports> set_output_delay -clock sdram_clk_pin -max [expr -2.0 - 0.6] <ports> set_output_delay -clock sdram_clk_pin -min [expr 1.0 - 0.4] <ports>
