18 years agoThanks for the tutorial!
Do you happen to still have the complete demo-design with the tested SDC file(s)? I am one of those who never had timing issues with their small/medium designs before, but now have... I am especially interested in properly constraining SDRAM/SRAM with Timequest - I followed your tutorial closely but for some reason my design fails all setup requirements for my SDRAM/SRAM input paths by a slack of about -5ns. This is @60MHz on a CycloneII quite much. Additionally there are setup violations for the ssram_clk_pin and sdram_clk_pin nodes - is this supposed to be not analyzed by a falsepath setting? Snippets from my SDC file (my SDRAM has the same characteristics as used in the tutorial):
# Create Clock
# both clock inputs are from the same crystal
# feeds PLL for system clock and SDRAM
create_clock -name {INCLK0} -period 30.518
# feeds PLL for SSRAM
create_clock -name {INCLK1} -period 30.518
# Create Generated Clock
derive_pll_clocks
create_generated_clock -name {sdram_clk_pin} -source {clkgen0|\alt:v|sdclk_pll|\nosd:altpll0|pll|clk} -offset 0.500
create_generated_clock -name {ssram_clk_pin} -source {clkgen1|\alt:v|sdclk_pll|\nosd:altpll0|pll|clk} -offset 0.500
derive_pll_c
# Set Input Delay
set_input_delay -max -clock sdram_clk_pin 6.100 }]
set_input_delay -min -clock sdram_clk_pin 2.900 }]
# Set Output Delay
set_output_delay -max -clock sdram_clk_pin 2.600 }]
set_output_delay -min -clock sdram_clk_pin -0.400 }]
TOP failing paths:
slack From Node To Node Launch Clock Latch Clock
-5.750 DRAM_DB sdctrl:\sdc:sdc|r.hrdata sdram_clk_pin clkgen0|\alt:v|sdclk_pll|\nosd:altpll0|pll|clk
-5.739 DRAM_DB sdctrl:\sdc:sdc|r.hrdata sdram_clk_pin clkgen0|\alt:v|sdclk_pll|\nosd:altpll0|pll|clk
-5.732 DRAM_DB sdctrl:\sdc:sdc|r.hrdata sdram_clk_pin clkgen0|\alt:v|sdclk_pll|\nosd:altpll0|pll|clk
-5.730 DRAM_DB sdctrl:\sdc:sdc|r.hrdata sdram_clk_pin clkgen0|\alt:v|sdclk_pll|\nosd:altpll0|pll|clk
-5.725 DRAM_DB sdctrl:\sdc:sdc|r.hrdata sdram_clk_pin clkgen0|\alt:v|sdclk_pll|\nosd:altpll0|pll|clk
-5.722 DRAM_DB sdctrl:\sdc:sdc|r.hrdata sdram_clk_pin clkgen0|\alt:v|sdclk_pll|\nosd:altpll0|pll|clk
-5.720 DRAM_DB sdctrl:\sdc:sdc|r.hrdata sdram_clk_pin clkgen0|\alt:v|sdclk_pll|\nosd:altpll0|pll|clk
-5.714 DRAM_DB sdctrl:\sdc:sdc|r.hrdata sdram_clk_pin clkgen0|\alt:v|sdclk_pll|\nosd:altpll0|pll|clk
-5.712 DRAM_DB sdctrl:\sdc:sdc|r.hrdata sdram_clk_pin clkgen0|\alt:v|sdclk_pll|\nosd:altpll0|pll|clk
-5.709 DRAM_DB sdctrl:\sdc:sdc|r.hrdata sdram_clk_pin clkgen0|\alt:v|sdclk_pll|\nosd:altpll0|pll|clk
-5.706 DRAM_DB sdctrl:\sdc:sdc|r.hrdata sdram_clk_pin clkgen0|\alt:v|sdclk_pll|\nosd:altpll0|pll|clk
-5.705 DRAM_DB sdctrl:\sdc:sdc|r.hrdata sdram_clk_pin clkgen0|\alt:v|sdclk_pll|\nosd:altpll0|pll|clk
-5.702 DRAM_DB sdctrl:\sdc:sdc|r.hrdata sdram_clk_pin clkgen0|\alt:v|sdclk_pll|\nosd:altpll0|pll|clk
-5.701 DRAM_DB sdctrl:\sdc:sdc|r.hrdata sdram_clk_pin clkgen0|\alt:v|sdclk_pll|\nosd:altpll0|pll|clk
-5.690 DRAM_DB sdctrl:\sdc:sdc|r.hrdata sdram_clk_pin clkgen0|\alt:v|sdclk_pll|\nosd:altpll0|pll|clk
-5.680 DRAM_DB sdctrl:\sdc:sdc|r.hrdata sdram_clk_pin clkgen0|\alt:v|sdclk_pll|\nosd:altpll0|pll|clk
Thanks for any hints or answers - and yes, I probably shouldn't follow blindly tutorials, but actually read the QII handbook to get my constraints right...
