14 years agoConstraining registered and combinational path independent of each other
I have a small CPLD project where one pin is connected to a register and also to some combinational logic, similar to the following code: library ieee; use ieee.std_logic_1164.all; entity test_max_delay is port ( CPU_WE : in std_logic; CPU_CLK : in std_logic; WE_comb : out std_logic; WE_reg : out std_logic ); end entity test_max_delay; architecture synthesis of test_max_delay is begin Reg : process (CPU_CLK) is begin if rising_edge(CPU_CLK) then WE_reg <= CPU_WE; end if; end process Reg; WE_comb <= CPU_WE; end architecture synthesis; Now I want to set up all three types of timing constraints: - Input setup & hold of CPU_WE relative to CPU_CLK - Clock to output for WE_reg - Propagation delay from CPU_WE to WE_reg When using the following constraints... set_time_format -unit ns -decimal_places 3 create_clock -name CPU_CLK -period 10.000 -waveform { 0.000 5.000 } [get_ports CPU_CLK] set_input_delay -max 7.5ns -clock "CPU_CLK" "CPU_WE" set_input_delay -min 1.0ns -clock "CPU_CLK" "CPU_WE" set_output_delay -clock "CPU_CLK" -max 2ns "WE_reg" set_output_delay -clock "CPU_CLK" -min 0ns "WE_reg" set_max_delay -from CPU_WE -to WE_comb 6ns set_min_delay -from CPU_WE -to WE_comb 0ns ...the input setup constraint from the registered path seems to be added to the actual propagation delay of the combinational path, i.e. input setup constraint: 7.5ns propagation delay constraint: 6.0ns actual propagation delay (CPU_WE to WE_comb): 4.631 Resulting slack: 6.0ns - (7.5ns + 4.631ns) = -6.131ns Is there any way to constrain the combinational path completely independent of the registered path or is there any reason why the input delay is added?
