14 years agoJust run:
report_timing -setup -npaths 20 -detail full_path -to [get_ports SR_*] -panel_name "s: sr" -file "TQ_setup_sr_out.txt" report_timing -hold -npaths 20 -detail full_path -to [get_ports SR_*] -panel_name "h: sr" -file "TQ_hold_sr_out.txt" Then attach the two files. What are the phases on your two PLLs? They seem strange(clk_0 has a slight negative shift, clk_1 has a +45 degree shift?)
