Altera_ForumHonored Contributor15 years agoConstraining Clock and Data Lines Hi everyone. I have a system with an FPGA and a DAC, both fed from the same 400MHz clock source. The FPGA logic and DAC input works at 200MHz (the DAC has internal x2 interpolation, so I provide t...Show More
Recent DiscussionsInterfacing Avalon Streaming FIFO IP with GTS Ethernet Hard IPInvalid license key (inconsistent authentication code)Regarding the issue of UFM not startingram retimingReset Release IP for Agilex needs Stratix 10 device files installed!
