15 years agoThis is intended for use with the Classic timing analyzer.
Timequest can do a very thorough analysis if you directly feed a PLL output to an IO pin but I personally think it's a hassle to set up (but worth the effort if you can't fit your interface into a single IO bank or using a DDR interface). Using the TFF and the Tco constraints enables you to use the Classic analyzer as well.
