15 years agoCan't think of any Classic timing analyzer setting that does this - this is a typical source-synchronous scenario for which timeQuest was created.
Depending on what FPGA you have and how many PLL outputs you have left, there _is_ a fairly simple solution for this, but you'll have to manually inspect timing every time you do a fit. If you give me a bit more info I can probably help you do what you need to. Best regards, Ben
