9 years agoConstrained clock appears as unconstrained input
Hello, I've spent a considerable amount of time several months ago to look into timing constraint issues, but had never understood how it works ... all this staff, despite several manuals I loo...
9 years agoMysterious !
In very similar design I did before there is no such issues. Short resume: TimeQuest analysis generates unconstrained path error on output dram_clk. This port delivers clock to external SDRAM chip and it's constrained with the following instruction: create_generated_clock -name clk_dram -source [get_pins {u0|pll|altera_pll_i|general[1].gpll~PLL_OUTPUT_COUNTER|divclk}] [get_ports {dram_clk}] Here is TimeQuest diagnostic, related to this DRAM_CLK port (setup analysis): unconstrained output ports: DRAM_CLK No output delay, min/max delays, false-path exceptions, or max skew assignments found. This port has clock assignment. unconstrained output port paths: From To From Clocks u0|pll|altera_pll_i|general[1].gpll~PLL_OUTPUT_COUNTER|divclk DRAM_CLK u0|pll|altera_pll_i|general[0].gpll~FRACTIONAL_PLL|vcoph[0] The same messages are present in hold analysis. Probably I've been mistaken with create_generate_clock instruction ? Thanks.
