9 years agoConstrained clock appears as unconstrained input
Hello, I've spent a considerable amount of time several months ago to look into timing constraint issues, but had never understood how it works ... all this staff, despite several manuals I loo...
9 years agoI've tried with zero delay buffer: with this option PLL generates an additional output, that should be connected somewhere. I didn't understand this option and finally selected "normal" option.
Also I din't increase PLL-generated clocks and didn't introduce phase shift. With this concept the problem didn't completely disappear - while with base clock (i.e. CLOCK_50), it's OK, DRAM_CLK still appears as unconstrained output. Here is fragment of Qsys: https://www.alteraforum.com/forum/attachment.php?attachmentid=14124 And here is .sdc file:#**************************************************************
# This .sdc file is created by Terasic Tool.
# Users are recommended to modify this file to match users logic.
# Create Clock
create_clock -period 20.0 -name clk CLOCK_50
derive_pll_clocks
derive_clock_uncertainty
# for enhancing USB BlasterII to be reliable, 25MHz
create_clock -name {altera_reserved_tck} -period 40 {altera_reserved_tck}
set_input_delay -clock altera_reserved_tck -clock_fall 3
set_output_delay -clock altera_reserved_tck 3
# Create Generated Clock
# **** next stetement modified by GooGooCluster ***
# create_generated_clock -name clk_dram -source .gpll~PLL_OUTPUT_COUNTER|divclk}]
# Set Input Delay
# Board Delay (Data) + Propagation Delay - Board Delay (Clock)
set_input_delay -max -clock clk_dram -0.048
set_input_delay -min -clock clk_dram -0.057
# Set Output Delay
# max : Board Delay (Data) - Board Delay (Clock) + tsu (External Device)
# min : Board Delay (Data) - Board Delay (Clock) - th (External Device)
set_output_delay -max -clock clk_dram 1.452
set_output_delay -min -clock clk_dram -0.857
set_output_delay -max -clock clk_dram 1.531
set_output_delay -min -clock clk_dram -0.805
set_output_delay -max -clock clk_dram 1.533
set_output_delay -max -clock clk_dram 1.510
set_output_delay -min -clock clk_dram -0.800
set_output_delay -max -clock clk_dram 1.520
set_output_delay -min -clock clk_dram -0.780
set_output_delay -max -clock clk_dram 1.5000
set_output_delay -max -clock clk_dram 1.545
set_output_delay -min -clock clk_dram -0.755
set_output_delay -max -clock clk_dram 1.496
set_output_delay -min -clock clk_dram -0.804
set_output_delay -max -clock clk_dram 1.508
set_output_delay -min -clock clk_dram -0.792
# Set Clock Groups
# Set False Path
set_false_path -from
set_false_path -from * -to
set_false_path -from * -to Any comments ?
