9 years agoConstrained clock appears as unconstrained input
Hello, I've spent a considerable amount of time several months ago to look into timing constraint issues, but had never understood how it works ... all this staff, despite several manuals I loo...
9 years agoThank you GooGooCluster,
I've just tried your suggestions. Unfortunately the result is the same - timing analysis reports two unconstrained ports - clock_50 and dram_clk. --- Quote Start --- If I understand you correctly, your PLD receives the reference clock at the CLOCK_50 pin, and internally routes that pin to the DRAM_CLK output pin; all external logic receives its clock from the PLD's DRAM_CLK pin. --- Quote End --- Yes, the FPGA (Cyclon V) receives 50MHz clock (generated on the board) at clock_50. Then this clock is "redirected" (assign DRAM_CLK = CLOCK_50) to clock external SDRAM chip. Concerning other SDRAM staff (i.e. DRAM_***), all these ports are clocked by the clock, derived from main system clock (i.e. CLOCK_50), as these interface ports are "created" by inserting the "SDRAM controller IP" in Qsys. I used a virtual clock for creating input/output delays for SDRAM staff, which you suggested to comment (i.e.# create_clock -period 20.0 -name clk_dram) because in all manuals that I'v seen until now it's this "mysterious object", named virtual clock, that is used for creating input/output delays. In the same time in all these manuals, the clock for external module is generated outside FPGA, whereas in my case (and I think in majority cases, it's FPGA, that delivers clock for external module). So, I consider your suggestion as quite reasonable, but unfortunately it didn't help ... probably due to some option improperly set somewhere. Regards.
