9 years agoConstrained clock appears as unconstrained input
Hello, I've spent a considerable amount of time several months ago to look into timing constraint issues, but had never understood how it works ... all this staff, despite several manuals I loo...
9 years agoHi,
If I understand you correctly, your PLD receives the reference clock at the CLOCK_50 pin, and internally routes that pin to the DRAM_CLK output pin; all external logic receives its clock from the PLD's DRAM_CLK pin. These changes should fix your warnings:...
create_clock -period 20.0 -name clk
# create_clock -period 20.0 -name clk_dram
create_generated_clock -name clk_dram -source
... The first statement defines a logical clock named "clk", which comes from the pin "CLOCK_50". You already had that, but I'm not sure if it really works without "get_ports()", so I added that. The second statement is, as far as I understand it, wrong, so I commented it out. The third statement defines another logical clock, named "clk_dram", which is basically the same as "clk", but measured with pin "DRAM_CLK" as a reference. I fixed the name of the clock that it generates. Below that, there should be all your set_xyz_delay statements, where you already use the clock name "clk_dram". Hope that helps. - GooGooCluster
