11 years agoconstant memory usage
Hi , __void kernel A(global int * restrict inputA) ; __void kernel B(constant int * restrict inputB) ; There are two kernels (A and B) . Why kernel B 's RAM / LE / FF / util is small...
11 years agoThe emulation ran successfully or the hardware synthesis? The emulation does not take utilization into account. So if your design was too large to fit onto the FPGA, the emulation will still run. If it was running after hardware synthesis, i think that the reason might be because there is still logic resources available, and so it tries to implement the operation using the available logic resources on the chip. Otherwise, I would expect the design to fail.
