13 years agoHi,
well this is part of a VHDL File "using" a Cyclone IV EPC4CE15 by 95%. The code is neither handy nor am I allowed to post it here as whole. I agree just posting snipets makes things not easier to investigate or explain. Regarding the libraries used - this is a "relict" of the first lines being written somewhat 20 years ago. While the content (the "working code") changed over the years the header of the VHDL file was copied each time... I played around a little with the suggested nummeric_std - this requires modification of the library declaration and to the code, does it? (i.e. SIGNAL xyz: STD_LOGIC_VECTOR(...) changes to either SIGNAL xyz: SIGNED () or UNSIGNED (), CONV_STD_LOGIC_VECTOR changes to TO_SIGNED () or TO_UNSIGNED ()...) While this is a lot of work, this might be a point to review more detailled the complete code and get rid of all those "historical" constructs. Carlhermann
