13 years agoActually, I think the issue may be not explicitly declaring the 2047 inside the third type as unsigned. For example:
constant XX : std_logic_vector(15 downto 0) := to_unsigned(2047,16) - alpha - beta, etc. I checked some code that I recently did, where I used a derived constant, and it synthesized fine.library IEEE;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.math_real.all;
entity calibrate is
generic (regSize : integer := 16);
port(
MCLK : in std_logic;
HRST : in std_logic;
ENABLE : in std_logic;
START : in std_logic;
Xin : in std_logic_vector(regSize-1 downto 0);
Xout : out std_logic_vector(regSize-1 downto 0);
DONE : out std_logic
end calibrate;
architecture rtl of calibrate is
constant Nsamples : integer := 4;
constant Z : integer := integer(ROUND(LOG2(1.0*real(Nsamples))));
constant N : integer := integer(Z) + regSize;
type accumType is record
val : signed(N-1 downto 0);
end record;
signal accum : accumType;
type counterType is record
start : std_logic;
done : std_logic;
val : integer range 0 to Nsamples-1;
end record;
signal counter : counterType;
signal load : std_logic;
signal doneDly : std_logic;
begin
Accumulate offset
FX: process(all) begin
if HRST then
accum.val <= (others => '0');
elsif rising_edge(MCLK) then
if load then
elsif START and not(counter.done) then
accum.val <= accum.val + resize(signed(Xin),N);
end if;
end if;
end process FX;
process(all) begin
if HRST then
Xout <= (others => '0');
if counter.done then
Xout <= std_logic_vector(accum.val(N-1 downto Z)) ;
end if;
end if;
end process;
Uedge1 : entity work.POS_EDGE(rtl)
port map(
CLK => MCLK,
HRST => HRST,
X => counter.done,
Y => doneDly
Udff1 : entity work.D_FF(rtl)
port map(
CLK => MCLK,
HRST => HRST,
X => doneDly,
Y => DONE
Edge detect enable mode
Uedge : entity work.POS_EDGE(RTL)
port map(
CLK => MCLK,
HRST => HRST,
X => ENABLE,
Y => load
Count the number of samples
counter.start <= START;
process(all) begin
if HRST then
counter.val <= 0;
counter.done <= '0';
if load then
counter.val <= Nsamples-1;
elsif counter.start then
if counter.val > 0 then
counter.val <= counter.val - 1;
else
counter.done <= '1';
end if;
end if;
end if;
end process;
end rtl;
