13 years agoWhich libraries are you using? I assume that you use one or more of the SYNOPSYS libraries. In this case I suggest to use the numeric_std library instead and try the following code:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
ENTITY constant_math IS
END ENTITY constant_math;
ARCHITECTURE rtl OF constant_math IS
CONSTANT PWM_DC_min : std_logic_vector(11 DOWNTO 0) := std_logic_vector(to_unsigned(120, 12));
CONSTANT PWM_Crossover : std_logic_vector(11 DOWNTO 0) := std_logic_vector(to_unsigned(6, 12));
CONSTANT RAG_max : std_logic_vector(11 DOWNTO 0) := std_logic_vector(2046 - unsigned(PWM_DC_min) - unsigned(PWM_Crossover));
CONSTANT RAG_min : std_logic_vector(11 DOWNTO 0) := std_logic_vector(2050 + unsigned(PWM_DC_min) + unsigned(PWM_Crossover));
BEGIN -- ARCHITECTURE rtl
END ARCHITECTURE rtl;
