11 years agoConstant / global memory
hi , Does access constant memory is faster than global memory and how fast ? If the access latency is the same , why do we need to use the constant memory ? Thanks.
11 years agoYes, constant memory access is definitely faster than global memory. How much faster, I'm not sure on the number. You can probably perform some tests on that.
The default cache size is 16kB.
