11 years agoConstant / global memory
hi , Does access constant memory is faster than global memory and how fast ? If the access latency is the same , why do we need to use the constant memory ? Thanks.
11 years agoThanks.
Therefore access constant memory is faster ( > 1x ) than global memory ? Or is there any detail number ? If I didn't use --const-cache-bytes <N> , the default max allocation is 1G (use helloworld to show the infomation) ? Thanks
