17 years ago
Connencting two alteara fpga board using Two USB blaster to the same computer
Hi All,
I connected two altera board using two USB blster, but insystem memmorry editor is detecting only one board at a time.
If anyone knows the setting ,please reply back
Thanks in Advance.
    Don't you have a selection between all available programming adapters as with other tools? I often use Programmer, SignalTap II and Source&Probe with multiple adapters.
    I've run into the same problem. I have a standard USB blaster, and a BeMicro; and they will not work at the same time. Device manager shows the second device with an exclamation mark, and indicates that it couldn't load the driver because a previous instance is already in memory.
    Seems to be a special driver installation problem. I have used both adapters (USB Blaster and BeMicro) plugged in simultaneously with WinXP SP2 and Quartus 9.0.
    FvM: are your USB Blasters all of the same rev? i think 2 Blasters of the same rev have the same device ID which does not allow multiple to be on 1 PC. i think there is a way to change them floating around here somewhere.
    --- Quote Start ---
    --- Quote End ---
    I think, I also used same revision some times, I can't recall it at the moment, but I can check occasionally. Generally, USB Blaster is enumerated by USB port. If I plug another (also different revision) device, they possibly change their logical port name in the JTAG server (like USB-1, USB-2). So they are apparently not distinguished by revision at this place.
