amildm
Contributor
4 years agoConnection bi-directional pin to SignalTap
Hi there,
How can I connect the bi-directional signal, which in defined as inout, to SignalTap?
When I connect this signal to SignalTap, the following error message is issued: "Error(17044): Ill...
amildm
Contributor
4 years agoIf in RTL I would define a module port as inout, but don't connect it to INOUT pin, then could I connect such signal/port to SignalTap?
- sstrell4 years ago
You could try, but the compiler would probably just optimize it away.
The only way to guarantee a connection to Signal Tap is to use the Node Finder filters.
