amildm
Contributor
4 years agoConnection bi-directional pin to SignalTap
Hi there,
How can I connect the bi-directional signal, which in defined as inout, to SignalTap?
When I connect this signal to SignalTap, the following error message is issued: "Error(17044): Ill...
sstrell
4 years agoWhen you double-click in the Node list to add nodes to tap, the Node Finder opens. That is where you set to use the Signal Tap pre-synthesis or post-fit filter.
