amildm
Contributor
4 years agoConnection bi-directional pin to SignalTap
Hi there,
How can I connect the bi-directional signal, which in defined as inout, to SignalTap?
When I connect this signal to SignalTap, the following error message is issued: "Error(17044): Ill...
amildm
Contributor
4 years agosstrell, thanks a lot for your reply! for some reason I cannot grant you a Kudo... I don't know why ... I've logged in to my account ...
Anyway, you wrote: " In the Signal Tap Node Finder, make sure you are using one of the Signal Tap filters to guarantee that you choose nodes that can be tapped by Signal Tap" - so, could you probably attach a screenshot of the SignalTap window and show how to use this filter?
