amildm
Contributor
4 years agoConnection bi-directional pin to SignalTap
Hi there,
How can I connect the bi-directional signal, which in defined as inout, to SignalTap?
When I connect this signal to SignalTap, the following error message is issued: "Error(17044): Ill...
sstrell
4 years agoYou can't connect any I/O pin directly to Signal Tap because there is no route from the I/O cell back into the FPGA fabric. You have to tap the register or logic that is feeding or being fed by the pin. In the Signal Tap Node Finder, make sure you are using one of the Signal Tap filters to guarantee that you choose nodes that can be tapped by Signal Tap.
