9 years agoconnecting to quartus
I use a STREAM board connected to a limemicro LMS7002 RF development board. The chip is an EP4CE40F23C7N, which is an FPGA board that can be programmed for RF communication with an RF board. I a...
9 years ago --- Quote Start --- I connect to the cable between Jtag cable and FPGA Jtag port. but i don't know how to use it in Quartus. when i connect it, there is no 'usb blaster', only 'usb serial converter'. so i can't use it in programmer menu. Please. What i have to do? --- Quote End --- I'm not exactly sure what you mean by 'it' ... have you connected a real Altera USB-Blaster? If so has the official Altera driver been installed for the USB-blaster, or is the installation picking up some other driver (like for a USB-serial converter) for that device?
