18 years agoHi Farrukh,
From my past experience. What I would do is convert each *.bdf into a *.bsf file. You can do this by opening the *.bdf file, then go to the file menu -> create/update -> create symbols file for current file. Then you can create a new Q II project and add your *.bsf to the top-level *.bdf. But you need to remember to add the *.bdf files into your current project. You can do this by going to the project menu -> add/remove files, then add all your *.bdf file names which you've instantiated in your top-level *.bdf. I hope this helps. Regards, pld_wiz
