skon
8 years agoConnecting an Avalon MM master with a 32 bit address width.
Hello, I want to connect an Avalon MM master with a 32 bit address width to 2 slaves that also have a 32 bit address bus each. Obviously, a straight connection is impossible...because of the overla...
skon
8 years agosstrell,
The spans do overlap.
You suggest using an "address span extender IP" while Tricky suggest an Avalon MM Crossbar.
Are both the same component ?
The reason I'm asking is because I couldn't find the Crossbar in the Qsys catalog...
