skon
8 years agoConnecting an Avalon MM master with a 32 bit address width.
Hello, I want to connect an Avalon MM master with a 32 bit address width to 2 slaves that also have a 32 bit address bus each. Obviously, a straight connection is impossible...because of the overla...
Tricky
8 years agoAssuming each slave is attached at different address ranges from the Master side, then you need an Avalon MM Crossbar to separate the slave address spaces into two distinct master busses.
