skon
8 years agoConnecting an Avalon MM master with a 32 bit address width.
Hello, I want to connect an Avalon MM master with a 32 bit address width to 2 slaves that also have a 32 bit address bus each. Obviously, a straight connection is impossible...because of the overla...
sstrell
8 years agoI'm not sure what you mean by the overlapping addresses unless you are saying these 2 slave components both use the entire 32-bit address space so you can't just connect them to the master. In any event, use a pipeline bridge to do what you mention.
