10 years agoConfused with set_input/output_delay command
Hi folks, while I am familiar with set_input/output_delay -max where it specifies the maximum time taken for the data to travel to and from FPGA, I am still very confused with -min value. I noticed i...
10 years ago --- Quote Start --- Hi folks, while I am familiar with set_input/output_delay -max where it specifies the maximum time taken for the data to travel to and from FPGA, I am still very confused with -min value. I noticed in most cases, we specify a negative value for -min but what does that actually mean? It will still take time to travel, just that the value should be smaller than -max but why the negative value? --- Quote End --- If the data arrives before the specified clock edge, then the delay is negative. The maximum or minimum delays specified could be positive or negative. The only restriction is that max > min.
