Anonymous
5 years agoNot applicable
Confused about connections in Quartus
I am a newbie!!
My project is to make 4 bit magnitude comparator using 2 bit magnitude comparator. I made connection but problem is that is didn't know what is the meaning of A[3..0] the input is ...
SyafieqS
5 years agoHi Chouhan,
I can see you did not connect the node or bus to a source signal. To do so, you can label/name the wire A and B for first above 4 and first below 4 respectively. Then, recompile it.
- Anonymous5 years agoNot applicable
Thanks for your Help.
