John-Monahan
8 years agoConfiguring the Quartus IP library "RS232 UART, CLK signal
I am trying to add the Quartus IP library "RS232 UART" into a .bdf file. Seems to load fine but during the "Generate" I get an error "The input clock frequency must be known at generation time." How...
John-Monahan
8 years agoThanks Vicky, I did see that info. I guess I should rephrase my question. Can I just ignore the Platform Designer Error described above and just go ahead an provide the baud rate frequency myself (as described in the article you identified). Will it work then?
