12 years agoConfiguration I/O voltage
I am attempting to locate 2.5V LVDS differential signals into Bank 3A of a Cyclone V device - this being the Bank that also contains the Configuration pins. In Quartus II - Device Assig...
12 years agoDid you determine if it is possible to have bank 3A at 2.5V? I am facing the same issue. I want to use AS config mode and also need almost all available LVDS inputs on the device. The documentation indicates that Vccpgm must be at 3.0 or 3.3V for AS mode, but from what I can see makes no mention of bank 3A Vccio requirements. If bank 3A Vccio must be at 3.3V, I cannot place all the LVDS inputs.
