10 years agoConfig via Protocol - periphery IO default voltage levels
I've started using Configuration via Protocol and I can get my board periphery loaded in time for PCIE and I can get the core programmed once Linux has booted on the host. In the meantime, it would ...
10 years ago --- Quote Start --- My understanding is that while in CvP mode, you can't hold various I/O at predetermined levels but tri-stated. --- Quote End --- Do you have any idea where this is documented? I haven't been able to find it in the UG for CvP or the Arria10 handbook. Thanks.
