Altera_ForumHonored Contributor16 years agoConcurrent DSE on Multi-core PC I have a 4 core PC. I would like to be able to run Concurrent DSE. Can I set loose concurrent compiles each on it's own core or pair of cores ? If I set the max number of processors to 2 and as...Show More
Altera_ForumHonored Contributor16 years agothis is true. also, be sure to bring lots of RAM if you run separate concurrent compiles.
Recent Discussionsstarting to learn FPGAsqsys-generate outputs Info as ErrorTiming analysis - long combinational pathQuartus Prime Lite 25.1 License Error - "Unable to checkout a license" (SALT_LICENSE_SERVER)Regarding the issue of UFM not starting
