17 years agoI would recode it as
COMPONENT DIVIDER PORT ( NUMERATOR: IN STD_LOGIC_VECTOR ( 9 DOWNTO 0 ); DENOMINATOR: IN STD_LOGIC_VECTOR ( 9 DOWNTO 0 ); QUOTIENT: OUT STD_LOGIC_VECTOR ( 9 DOWNTO 0 ); REMAINDER: OUT STD_LOGIC_VECTOR ( 9 DOWNTO 0 ); ); END COMPONENT; Note each port is a single declaration I think the "Is" after the component declaration is only valid from VHDL 93, so you need to check that you are compiling for 93 not 87 So for 87 use the following COMPONENT DIVIDER ... END COMPONENT; and for 93 use the following COMPONENT DIVIDER IS ... END COMPONENT DIVIDER; Also, check you have included the correct libraries atthe start of the file library IEEE; use IEEE.STD_LOGIC_1164.all; Hope this helps
