13 years ago
Component Instance "XX" is not bound - Modelsim
Hi
I´m trying to simulate a design in modelsim altera starter edition 6.6d.
All the files (vhd) compile but when I start the simulation a warning message is displayed:
Warning: (vsim-3473) Component instance "adder1: altfp_add_sub" is not bound.
I can run the simulation but the output of this adder is always "XXXX".
It also happen with a FP divider but not with a FP multiplier, it has not problem.
This is how I'm creating the instance of the altfp_add_sub component:
LIBRARY altera_mf;
USE altera_mf.altera_mf_components.all;
adder1 : altfp_add_sub
GENERIC MAP(
[/INDENT]denormal_support => "YES",
[/INDENT]intended_device_family => "Stratix III",
[/INDENT]direction => "VARIABLE",
[/INDENT]exception_handling => "YES",
[/INDENT]optimize => "SPEED",
[/INDENT]pipeline => 8,
[/INDENT]reduced_functionality => "NO",
[/INDENT]rounding => "TO_NEAREST",
[/INDENT]speed_optimized => "STRATIX_ONLY",
[/INDENT]width_exp => 8,
[/INDENT]width_man => 23,
[/INDENT]lpm_hint => "UNUSED",
[/INDENT]lpm_type => "altfp_add_sub")
PORT MAP(
[/INDENT]aclr => clr,
[/INDENT]add_sub => add_sub_reg,
[/INDENT]clk_en => en,
[/INDENT]clock => clock,
[/INDENT]dataa => output_mux1_reg,
[/INDENT]datab => output_mux2_reg,
[/INDENT]result => output_adder);
Please, can someone tell me what is wrong?
    I have reviewed the mf_altera package/library from my version of modelsim and it seems that the components altfp_add_sub and altfp_div are not included, only the altfp_mult is in this package.
    I have worked previously with these components but creating them from Quartus using the Megafunction Wizard which creates the files needed for Modelsim to simulate the components.
    Now I see that apparently some components can not be instantiated using the component declaration directly.
    --- Quote Start ---
    Hi
    --- Quote End ---
    This commonly happens if your instance interface doesn't match to your component interface declaration.
    Check if the port and generic interface of your component and the respective instance are equal.
