8 years agoCompiling with different seeds and Aggresive optimizations
My compilation failed due to complex routing. !=========================================================================== ! The report below may be inaccurate. A more comprehensive ...
8 years agoOn Arria 10 with the standard flow that uses partial reconfiguration, Block RAM utilization above 95% and logic utilization above 75% will very likely run into fitting or routing failure. In your case you probably need to focus on reducing the logic utilization by 5 to 10% for the design to become routable.
